I got an alesis key board in for repair with a bad ac hum (60 cycle). I found q6 and q7shorted and replaced them. The hum got much better but is still present and noticeable. These transistors were on the -5 v. I have seen regulators cause problems in the past, But I also have an op-amp in the same circuit as the two transistors. I don't want to just throw parts at this thing so I thought I would put this out. Has anyone had this or a similar problem and if so, what was the cure?
thanks in advance, skip2011
