Someone on this board posted years ago about a bad run of caps made by some manufacturer, and used by quite a few manufacturers in computers and consumer electronics.
Since then, I've managed to fix several computers by just replacing any swelled caps. I don't know much at all about solid-state electronics, preferring to tinker on my old tube amps.
My latest victory is a 42 inch flat-screen HDTV. It wouldn't power up any more, and was given to me.
"I know you like to tinker, so here's a TV that doesn't work. If you fix it, it's all yours. Otherwise, heave it in the dumpster!"
I found 4 swelled caps in the power supply. I replaced every cap in that section, swelled or not. Cost me somewhere around 2 dollars. The TV powered up, and is much nicer (and bigger) than my old TV.
So, thanks, gents, for the incredible resource of knowledge this board provides!
