So every time I see a Triplett or Simpson or Tektronix something or other that doesn't work, kind of works, or is unknown in functionality for very cheap it is hard for me to NOT buy it. You know, like when you come across a Triplett 630 untested for $20 and it doesn't look beat up. Ok, sure I'll give it a try.
I am enjoying exploring and attempting to repair and calibrate this kind of gear. Wondering if anyone has comments on what could be a good route to try to cal this old gear to the best of my ability.
My thoughts:
1. Pay a pro for a thing or two and use it as cal reference for my other gear. There is a Tektronix site that is not far away. They will cal VOMs and DMMs for about $65 each, although it's $77 if you want cal documentation with it. As a scope $$$ reference I asked about a Tektronix 465 cal, which was about $155. A higher level of NIST cal is also offered. I don't know how much it costs but I don't think I even want to.
2. Use my own references which are probably pretty good, but not "spot on."
I have a
- Tektronix TDS210 digital oscilloscope. This is might be my best option because it is self calibrating and passes all its own calibration checks. I hope it is telling the truth and is pretty accurate. It's still from the early/mid 90s though I think.
- Tektronix 465 which was last calibrated in 2002. Seems basically agreeable when compared to my Tek TDS210
- Fluke 27/FM true RMS DMM. These are totally old but I have two that were army calibrated semi-recently. 2008 and 2012.
- BK Precision 2709B DMM. This the only piece of new gear I own so I would hope it would come from production pretty accurate. All other test equipment I have is like 15 years old minimum. This meter is is 18 months old and reads slightly off with the Flukes!!
3. Purchase semi-espensive gear that I'm not that familiar with as a true reference and go DIY. Maybe stuff like this.
- Extech Voltage/Current Calibrator -- Does 0-24mA and 0-20V
- Fluke 382A Voltage/Current Calibrator -- Does 0-2A and 0-50V.
- Martel BC 2000 Voltage/Current calibrator Does 0-200mA and 0-20V.
- Buy precision resistors or calibration resistors for ohms settings
My thoughts:
I have a
