eminance 15" 8 ohm speaker specs
  • eminance 15" 8 ohm speaker specs
ID:	869293 im looking for cabinet specs
    They have a software designer.
    Designing Enclosures is easy with Eminence Designer Software | Eminence Speaker
      its a older speaker cant seem to find any info for a 55-755
        What is the intended purpose? If it's for guitar, it's not horribly critical. Find something close. A bit more critical for a subwoofer.
          Pa sub woofer
            There are some specs on this page.
            http://www.rdrop.com/users/billmc/speakers.txt
            Looks like it was made by Eminence for MCM
              You got lucky
              Anyway, most modern Speaker Software has built in speaker measuring, which only requires adding a known weight (a couple US coins) and an "interface box" as complex as a couple banana jacks , a 1k resistor and an extra 10 ohms one for calibration.
              Signal , sweeping, measurement, all are done in software using the PC sound card.
