Unknow component in a power amp
  • Unknow component in a power amp
    Hi all, I need your help, I have a power amplifier a subwoofer (AXYS Uniamp 700), which has no voltage on the diode bridge, the only component that seems not right is this: KVR 10-471, according to the pcb is a NTC but can't find information about it, if anyone can offer any type of information you would appreciate with well cold beers you come for Spain!
    Thank You!
ID:	869415Click image for larger version
    I thought it was a varistor, 10mm 470V.
      Yeah, it is an NTC varistor.
      The 'NTC' implies that its a type Negative Temperature Coefficient.
      It will start at a high resistance & as it warms up the resistance will drop.
        So are we all off to Spain then for some beer G1 and JP Bass ?
        I put KVR 10-471 in google first "hit" =
        Vatronics MYG GENERAL PURPOSE VARISTORS
        http://www.vatronics.com/Upfiles/down/201171885402.pdf
        Nominal Varsitor Voltage at 1mA DC 470
        Rated Voltage (V)
        ACrms 300
        DC 385
        Clamping Voltage (V)
        810 - 775
          Just beer?
          I'd ask for some Paella:
            I believe Spain's Paella is wurst after the bailout...
              THe NTC marking on the board is a little confusing. An NTC usually goes in line with the supply and a Varistor is a shunt device that behaves somewhat like a pair of opposing-series Zeners, or a gas-discharge tube. AN NTC anti-surge protector has a low resistance (just a few ohms) that falls as it warms up and acts as a soft-start. A Varistor does not conduct under normal operating voltages but will do so when a particular threshold is reached. Sometimes they're placed after a fuse so that the fuse deliberately blows under higher-voltage conditions.
              They do get tired if the breakdown voltage is repeatedly approached and can fail on their own, sometimes with no other fault present.
                Mick is right.
                So I guess the question is, is it connected parallel to a source or in series with whatever load there is?
                If parallel, certainly is a MOV; Series, most certainly an NTC of some sort.
                  There is also a marking on the board right by there that says Var2. So I'm wondering if they use one or the other?
                    That's the first thing I did yesterday. But it's a Varistor no a ntc, Thanks
                    Rated Voltage (V)
                    ACrms 300
                    DC 385
                    810 - 775
                      Yes, the NTC is connected in series with the diode bridge, the question is what kind of ntc is? Thanks!
                      Originally posted by diydidi View Post
                      Mick is right.
                        That's not paella, The "real paella" is this
                          I am surprised at the confusion, NTC1 is the part designation for a NTC Thermistor that is in series with the load, as a slow start mechanism. Very many amps have them and they are not that uncommon to go bad.
                            I think the confusion arises from it looking like a MOV, being spec'd as a MOV, but being marked NTC and connected in series.
                              Spec's as a MOV? It says 470 ohms on it, it has a board designation of NTC1. The original probably works, not burned as is the normal failure mode, just the lead broke possibly due to vibration.
                              casinolevant levant casino
