Ok, this is an oldie. Initial complaint was distorted sound, very low output, and IOC lights on
Upon inspection, I found bad/open R2 (2.2k) and an open circuit board connection under the Jack panel that buts up to the main PCB.
So I fix that, change the Electrolytics on the PCB that feed the OP Amp PS. They were ok both with ESR test and Cap Value test, but I changed them anyway.
Fire it up and all seems well with no load. Good signal all the way to the posts. NO offset.
Connect a speaker load, and it starts lighting up my bulb limiter and humming away. No sound. Same issue L or R
Same thing even when input signal is disconnected. As long as a load is connected, something is amiss.
Checked every last transistor. They seem ok. Diodes too.
I can't recall ever having a power amp do this loaded but not unloaded.
IOC lights DO NOT come on.
Any Ideas?
Any Ideas?
