Hello - I have a Peavey 200H (A Series) Power module (from a XR400) with a high DC offset at the output ( around .37 volts).
The power transistors dated to 1980 and it looks like an A series power board
History: R20 was open and roasted R14 and R15 making a new path to ground; in the process two of the output transistors blew.
What was done so far:
Q7and Q10 are original transistors (checked out with meter)
Q8 and Q11 were replaced with MG15015 transistors.
R20 was replaced (.33 ohm/5 watt)
R14 (100 ohms) and R15 (120 ohms) were replaced
C13 and C14 were replaced due to age
C15 and C16 were replaced due to age
Q4 and Q5 were replaced (but original were not bad - no change)
CR7 was replaced (not blown - but as a precaution)
I swapped Q9 and Q3 with no changes
The transistors check out to be good (no opens or shorts)
Powers up; no smoke - just high DC on output
Note: I did not connect a speaker nor did I connect the front board.
Voltages:
Rails +/- 40.5 V on both sides
.31 Volts across R9
+.8 Volts at the anode of CR4
-1.46 Volts at the cathode of CR8
-1.3 volts at the anode of CR7
Any thoughts where to go from here? Could the 2 original output transistors (Q7 and Q10) be bad even thought they meter out as no opens and no shorts?
Thanks ....
Voltages:
.31 Volts across R9
Thanks ....
