Technics Digital Piano Damper Pedal
  • Technics Digital Piano Damper Pedal
    I have a Technic Digital piano with a set of broken pedals. As I cannot find the right cable for the pedal, I was hoping there is a way to connect a separate damper pedal with a 1/4" male jack. If anyone could give me information on whether this would be possible that would be excellent. Here's a picture of the pedals input on the piano. (FYI the cable that attached to this jack previously connected to three pedals)
ID:	870114Click image for larger version
    I would guess that it would be possible, but the drawing that you have supplied does not contain enough information to tell you if and how it can be done.
    Did you create the little layout drawing? Do you have access to a schematic? What is wrong with the current pedal?
      Also, the terminology can get confusing. Damper is usually the sustain, but please clarify.
      Which pedal on the drawing are you calling "damper" ?
      alanya escort
      www.oje.net
