Does anyone know how to take the back off to change the DC socket?
Korg SP-300 info needed
It is not so much 'taking off the back' as 'taking off the top'.
Opening the SP300 is fairly straightforward. You need to take off the screws going into the bottom panel, then you can remove the front bar, and then the wood bottom. There are three types of screws. The larger machine screws hold the keybed assembly to the wood bottom. The side panel screws are longer wood screws. A third set of screws runs along the back.
Drewline Hello. I have a Korg Sp-300 and I'd like to clean under the rubber contacts, because one of my keys produces maximum volume when touched. I started disassembling the piano, but i just can't remove the keys (after removing the wooden plate) and I'd really not prefer having to remove all screws from the buttom, inside part. I can't seem to send you a private message, to ask for that service manual, because I've just registered. Can you help me out in some way? How do i remove the keys? I've searched all over google, but none of the tutorials could help me, the keys are fixed in a way that seems very different from other mechanisms.
Thank you in advance,
András
Thank you everyone, Drewline successfully sent me the manual via e-mail. However, the manual doesn't provide any assistance in the disassembly of the interior of the piano. I guess It was meant for professionals who already know their way around a digital piano. Does anyone have any idea on how should I remove the keys? Should I share some photos?
