What's your favourite piece of DIY test gear? Here are three items of scrap-box test equipment that I use pretty much all the time. Simple to build and do the trick. To someone else they may look like junk but I wouldn't be without them.
The transparent box with the traffic-light display is a modified Dick Smith ring tester. It's never once failed to detect a shorted or low-resistance turn on a choke or transformer and is super-sensitive.
The white box is a simple 1Khz sine-wave oscillator, built in the '70s and apart from a new knob and switch has served me since. It's still my go-to unit for 'scoping an amp or injecting a signal to track down a faulty component or section. It's reliable, simple and predictable.
My ESR meter was built from a re-calibrated salvaged meter movement and housed in an old A-B switch box, covered with some scrap vinyl-cut material. The guts is made from parts out of an old desktop PC SMPS. I use this an awful lot, especially on old gear. I can check every cap on a board in-circuit in just a few minutes.
