I've just been checking over an amp and it's showing lower than expected voltages. It's a US-only model, 120v/60Hz. I'm running it off 120v/50Hz for test purposes. Usually it's run off a 240v/120v auto-transformer
The EL34 heaters are reading 5.48Vac and preamps are 9.7Vdc. B+ is 440V.
I noticed the PT growls a little more than usual. My though is that the PT may be tightly specified for 60Hz. Could it be saturating and losing efficiency to the degree of dropping the output voltage on 50Hz?
