Alesis Quadraverb s5 LCD issue
  • Alesis Quadraverb s5 LCD issue
    I have an old Alesis Quadraverb keyboard the first iteration of it. The lcd started going real dim kinda of like and old lcd watch in the sun, numbers barely there.
    Any chance someone out there has a schematic for one or can help work something out for a replacement lcd? Alesis doesn't have any instock as its old 1994.
    Thnaks,
    nosaj
    Is it a Quadrasynth (keyboard), or Quadraverb (rack mount effect)? The description is confusing. I don't have a schematic and good luck getting one from Alesis. There should be a couple of separate pins on the display for the backlight which is normally 5V on those. I'd start there and see if you have backlight power.
    At any rate, if it's just the backlight, I'd give these guys a shout. I've used their backlights many a time for all sorts of gear. If they don't have it, they'll often build it for you.
    http://www.telesisgear.com/id16.html
    If it needs the display, the Lumex displays that Digikey sells often will work. You usually have to transfer the header, but otherwise (if you get the right one) they are drop in replacements for many Alesis products. Here's an example (I believe for the Quadraverb). You'll have to peruse for your specific piece.
    http://www.digikey.com/product-detai...1760-ND/469798
      Sorry Quadrasynth keyboard.
      nosaj
        Don't know if you are still in the hunt, but...
        I ran across this looking for something else:
        ALL ALESIS SPARE PARTS - Alesis Spare Parts
        They have two different Quadrasynth displays listed, not sure what number QS you have.
          I found them here
          Advanced Musical Electronics
          8665 Venice Blvd.
          West Los Angeles,CA 90034
          Mon-Fri 10am-6pm Sat 12pm-5pm
          310-559-3157
          Musical Instrument Repair | Advanced Musical Electronics
          Thanks to Stan from Russia he sold his inventory to them.
          It was for the first version which your link doesn't carry.
          Thanks though,
          nosaj
            Alesis Quadrasynth s5 keyboard address error
            Originally posted by nosaj View Post
            I found them here
            8665 Venice Blvd.
            310-559-3157
            Thanks though,
            nosaj
            Ok I got the display installed and now am getting an address error. Anyone got any suggestions for this? I've seen mention of using a data disk or a soundcard any idea where I might find one for this one?
            Thanks,
            JasonClick image for larger version
ID:	842258Click image for larger version
