Hi folks, I'm new around here and looking for some guidance with a weird issue and a second weird issue which I seem to have created while trying to fix the first one.
I'm attempting to repair a CFX 12 which has an issue where it will generate a regular 'pop' noise on the master output. Initially this would only happen when channel 1 gain was near max and the channel, group, and master faders were near max. I could do the same with any other channel without any issue. The popping gets faster as I turn up any combination of channel gain, channel/group/master fader, tape input, headphone output, utility output. Eventually if enough of those controls are turned up high, the popping stops but the mixer either doesn't pass audio or it is very distorted.
To try and locate the problem I tested the power supply capacitors (didn't see anything wrong) and the capacitors on the channel 1 circuit strip that I could test without desoldering them. As channel 1-4 are on a secondary PCB attached via ribbon cable, I had to take that PCB out to test it before putting it back in.
Now (after reinserting channel 1-4 PCB) channel 1-4 faders produce a high level of scratching noise whenever they are moved, their mute buttons make a weird noise when pressed, and their output is much lower than it should be so they require tons of gain to pass a signal.
I've tried reseating the ribbon cables that connect that board to the main board with no effect. And here's the kicker: Now the popping noise is present when I turn up the tape/headphone/utility controls without channel 1 maxed like before. So I disconnect the channel 1-4 PCB entirely and the popping still occurs, so the initial problem doesn't appear to be on that board anyway.
Sorry if this is a bit confusing, I've tried to explain it as well as I can.
I'd definitely appreciate any ideas!
