Yamaha J-25 Guitar amp
  • Yamaha J-25 Guitar amp
    A friend of mine Yamaha J-25 Vintage amp bias trim pot burnt and doesn't know the value.
    Help also with value and current setting .And also Japanese vintage NISSHIN ONPA (Maxon) GT-10 guitar amp output power amp Ic lost and not known, Could TDA 2003 be a replacement?thks
    I do not think that there is schematic available for this particular amp.
    That said, the bias pot on most Yamaha amps like this one is 500 ohms Linear.
    I have attached the JX 40 power amp & adjust proceedures for the bias (Note: for reference)
    If your output section is similar, the bias test points are on TR9's emitter resistor.
    JX 40 Pwr Amp.pdf
    JX 40 adjust.pdf
      thks,Jazz P Bass.....
        With your GT-10, does the power amp IC mount onto a circuit board - if so, how many pins?
        The TDA2003 could be made to work, but there could be compatibility issues that prevent a straight swap. Without a schematic it's down to trying to work it out from scratch. A start would be to identify the ground, power supply and signal input/output connections.
        Do you have any test equipment?
          Agree, TDA2003 possible only on a very old amp, needs 12/15V single supply; TDA2006/30/40/50 are split supply and incompatible with 2003 .
          They might even have used some Japanese IC , uPC sometging or reallyt anything else.
          Post an IC closeup picture, is any printed code visible?
          Even if partial.
          Of course state what kind of supply (single/double) and voltages do you read, as suggested by Mick Bailey .
          Edit: here's JX30, we're getting closer
          JX30BYAMAHAServiceManual-EN.pdf
            Finally,TDA2030 worked in old GT-10,thks J M, so much for JX30 schematic. What a Classic manual.....
              YAMAHA J-25 has a trim pot of 470 OHMS.. i just repair 1 this week..
              you can tweek the trim between 2 and 3.. that is were its originally set.
              there is a reason why the trim pot is burned.. you have to check the transistor in the power amp stage, there's a shorted 1 or 2..
                Thanks alot juturnadee182.
                My amp has to be gathered alot of parts including 470 Ohms Pot and Output ICs.
                Thanks for the information and Hope I can repair upon Your datas.
                Bye.
                  Bye.
                  sawmichael how's your friends j-25 amp now?
                    It was already damaged.My friend put it outside in the rain and the next time I went to see it's finished.
