What do I need? I have been using a function generator on my phone but I would like to have something different. There are a lot of ranges in prices.
Audio generator
Go get one from Enzo. he is in Lansing
Or Stan would recommend this as a basic, cheap, good audio generator.
http://www.radiomuseum.org/r/heath_a...ig_5218_i.html
Of course it really depends on your needs and what you are working on, which I'm sure someone will ask you to elaborate on
If you don't mind used stuff, there are plenty of decent used generators on eBay. If you are just using it to trace audio through a circuit, you don't really need anything fancy."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Velleman Signal Generator Kit : MK105 https://www.amazon.com/dp/B000TA3FKS..._AXQUwbK6ZKWQY
I took a second to find this. If you want variable frequency there are inexpensive kits out there as well.
Originally posted by E biddy View PostThis isn't the future I signed up for.
I'll PM you. I have several generators that are projects - in need of various rebuilding. But I do have a neat old Heathkit that I believe works, and would work for you. I'll check it out first.Education is what you're left with after you have forgotten what you have learned.
