I have an Egnater Renegade 212 combo. About a couple of years ago I lightly wiggled the EL34
tube, which was about 3 millimeters from complete insertion from the El34 tube socket, while
the amplifier was still on, and the fuse blew causing the amplifier to have any power.
I took the amplifier to a local amplifier repair shop in town, and the amp tech told me
a washer was smashed, causing damage on the pcb board. He put a lot of work in repairing
the amplifier but could not get it up and running. He decided just to charge me a bench fee
which was satisfactory compromise to me.
I took the amp home and ran it under a variac at about 90 volts. Everything lit up and the
amplifier seemed to be funtional. I decided to plug the combo speaker which was stock for
this amplifier and when I did, the fuse blew again.
Please help me troubleshoot this problem if you will or give me some suggestions.
Thank you.
Thank you.
