Let's say I have a 50/50uF 500v cap can. Can I wire one cap can in series to get 25uF/1000v?
Can Capacitors question
Does each section have an individual ground? Usually the answer to this is "no," and so no you can't wire them in series... if the answer is yes, then yes you can.
If one of the better minds here says otherwise, I will humbly stand corrected and delete my post, will have learned something, and will be asking the same question!
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
