I have a small piece fo Alesis demonstration gear. Back when they were selling Microverbs and MIDIVerbs, they made a little box to compare them. It was made for the music stores selling the units. The little box was made in the same extruded cabinet as the microverb. All it was was a signal source and a selector switch. It had two pushbuttons, and each played a sample. One was the short sound, and was a snare drum hit. The other was a long sound, and was like a chord struck and held as it fades. Pressing either button played that sound. On the rear were three return jacks, routing the sound sample from three units being demo'd, an output to some amp for listening to the result, and an output from the sound generator to go to the demo units.
On the front a small switch selected which of three you would hear. There was also a front AUX in jack in case you wanted to play some other sound into it.
That's it, it plays a snare hit or a chord at the press of a button, and acts as a basic signal router.
Normally I am pretty good at google, but I can't find this thing. To make it worse, Alesis made a much more sophisticated demonstration unit later, with LCD screen and more capability. If I search for demonstration unit, I get you tubes of product demos. If I try to get specific enough to find a demonstration thingie, I only find that newer fancy one.
ANyone have any thoughts?
And it is for sale, if I can figure out what to call it.
