Hello everyone, I have a problem with the active subwoofer Mackie swa1801. The problem is this: I turned on the sub that for many months, and I turned on not raising the volume from my phone lights up the led thermal. Viewing manual means that the temperature exceeds 60 degrees, and should also go mute but feels the same but I had just turned on. I disassembled the amplifier and I noticed first by the smell of something hot and then I had confirmed with my finger that I burned by touching the resistance r65.Prima I became aware of the resistance I raised the pot that's on panel and (do not know why I did it), the red led is lit thermal altogether and burned the transistor q12 . the transformer is not original because I took the sub used and that the former owner had changed with a more powerful (if you do not know what he meant with more tension hope not or higher amperage) because it was burned. Before I realized the problem I noticed a sound distortion. What could it be?
Sorry if the text is not particularly spelled it right because I'm Italian and I do not know much English.
