My Behringer amps drop out and come back in. Preamp signal is good, but the power drops out at random. First it was only on the mains, now it drops out on the Monitor side as well. I first thought it was bad cables, so I replaced/repaired all cables. It did pretty well until a pedal steel guitar player unplugged his microphone under full power and the plugged a different mic in...POP! It died completely on the amp side. Rebooted and it came back up but only powers about forty percent of the time: dead the rest of the time. Its a EuroPower 1200 watt (highly exaggerated at that).
Behringer PMP3000 board
Originally posted by diydidi View PostCheck the preamp out and return jacks.Originally posted by tdcarnut View PostI'm not using preamp out: all internal.
See this sticky post about the issue: http://music-electronics-forum.com/t28549/Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostHe was probably referring to the switching jacks (inserts and returns) that can cause exactly the problem you have.
