Milbert amps?
  • Milbert amps?
    Check out this AD which I partially quoted here for Milbert amps. Wonder how they pulled it off. Would love to see the schematic for one of these
    [quote]
    Adjustable from 1 up to 15-, 30-, 60-, or 90-watts, yet only 12 pounds total weight
    Interchangeable features may be changed for look, or removed to cut weight even further
    Uses patented designs by David Berning, one of the world's premier audio designers
    Hand-wound power magnetics & impedance converters
    Transformer-less design eliminates drawbacks due to 'necessary evils' in traditional amps
    No low-frequency saturation, high-frequency roll-off, or phasal non-linearities
    Accepts 36 types of power tubes in any combinations; input tubes can also be changed
    Plays "matched" tubes as well as tubes of completely, even wildly different types
    Plays all standard tube complements and allows over 1.6 million other combinations of tubes
    No adjustments required - all combinations of tubes are auto-biased
    Impedance converters attain correct theoretical output transformer turns ratio
    Automatic protection circuitry
    Ramp-up turn-on delay extends tube life
    10 - 20 years tube life depending on use
    Low impedance output drives a wide range of speakers and is not damaged by no load
    Class AB output stage; 2 push-pull pairs, can be used imbalanced for tonal effect
    No heavy power or audio transformers - little or no hum
    Domestic or Universal (autosensing 100-240VAC 50/60Hz) power supplies available
    Fits anywhere, even inside a "small head" case with room to spare.
    P3™ Phantom Power powers pedals and active pickups through the signal cable
    Premium components and craftsmanship, made in USA[quote]
    Milbert GAGA Guitar Artists Guitar Amplifier
    Are these self biasing amps cathode bias? Would they still bias in the correct range with different tubes?
      Class D power supply? Valves for 'color'?
      slot siteleri
