Hello,
I have a Fender 3016 powered mixer with intermittent sound problems. The sound can range from no signal getting through at all to partial signal to full signal. It does not seem to be correlated with length of time the unit has been on or any heat related issue. It also does not seem to be correlated with mechanical vibration. What does make a difference is if a large signal is suddenly input - like I whack my hand on the mic. It seems to "wake it up" and full sound returns. I've done this enough times that it is definitely not coincidental. Also, the problem occurs on all input channels - it is not channel specific.
Any ideas what might be causing this intermittency keeping in mind that a large input signal seems to restore sound?
Thanks,
Greg
Thanks,
Greg
