Hi
im having hard time figuring out what is wrong with my behringer mixer. The problem is that I can't get the main output(this one has joined L & R) to output any Left sound.some noise but not real sounds.Adding to that there is no blinking on the left led strip only right.
Already found ultible threads about this issue with sl2442 and figured out it would be the op amp so I removed one from the 24 line and soldered it onto the IC51 spot reasoning for that was that it gave different reading when measuring the resistanse (propably not the right way to check op amps) It would be really cool to get this mixer to work so really hoping somebody could help me.
ps. main output does give out left when using solo and the left led strip also works. Also I don't speak english natively so please don't give me hard time for that.
