Originally posted by Steve Conner
View Post
i have seen the 1W high output LEDs in the catalogs, but I never knew that they made side-light models specifically for radial illumination when the LED is mounted to a hole drilled into a plexiglass plate. that kind of design would simplify the edge-lighting problem.
of the three types that they list (hey use nomenclature like "side emitting," "batwing," and "lambertian"), I think that "side emitting" is what I'm after. according to the spec sheet, most of the illumination with that model is at 90-degrees. sounds perfect.
View Post
