I'm just curios if anyone has enough experience with these things to tell me whether this might be a counterfeit or not. It was purchased as "Original Sanyo". I'm having serious doubts if that's true. Looking at the actual output devices within the part (on the heat sinks), they look substantially smaller than the ones from an original part and it seems suspect to me. I could certainly be wrong. It's been a while since I cracked one of these open. The reason I ask is because this is the second failure in this amp- both times the STK was replaced. The IC's for each repair came from different vendors. I want to make sure I get a "real" part next time, if that's even possible. I'm thinking NOS versions of these are rare as hen's teeth. BTW, the amp is the GC Acoustic B200H.
For your viewing pleasure:
