I'm having trouble locating the test points on a circuit board. I see them on the schematic, but can't for the life of me find them on the actual board. My question is; Can a TP in the circuit not always be a pad/terminal and instead be a lead from a component or something else entirely?
Question about test points on a PCB
My gut says yes, but, what are you working on, and can you put up the schematic and test point layout, etc? You'll get more info if you give more info...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by HNKTNK View Post...Can a TP in the circuit not always be a pad/terminal and instead be a lead from a component or something else entirely?
Originally posted by Justin Thomas View PostMy gut says yes, but, what are you working on, and can you put up the schematic and test point layout, etc? You'll get more info if you give more info...
JustinAttached Files
Test points are places in the schematic. Only rarely is there an actual "test point" on the circuit board. The schematic test points are what they appear to be: the end of a resistor, the emitter of a transistor, the cathode of a zener, etc etc.
Once in a while for setting bias, you might find a power amp with two little posts sticking up to measure a voltage - rather than getting right on an emitter resistor.Education is what you're left with after you have forgotten what you have learned.
I was wanting to remove it and then jump tp11 and tp12 to see if I get any output out of this thing
First, listen to the relay or put your finger on it. Does it click on after a few seconds at power sup? If not, there is the basic issue. But there will be a reason the relay does not click on, you want to find that out before cross connecting the output. Is ther DC voltage sitting at TP11? Is there signal at TP11?
If the relay does click on, then look for signal at TP11. Also do the basics, plug a guitar or other signal into the power amp in jack, get sound? Likewise plug a cord from preamp out to power amp in and plug guitar into the regular input jack. Sound?
If the relay does not click on, it COULD be a bad relay, but far more common for the relay to not be turning on electrically, the relay doing its job in other words.Education is what you're left with after you have forgotten what you have learned.
No relay click:
Then we need to isolate the problem to either the relay itself, the power supply to the relay, or the circuit that controls the relay.
You want to find if the relay coil has power. The terminals are under it and hard to get to, but diode D19 is parallel the relay coil, so measure there. DO you see about 60v on the cathode? Note TP18 is the line controlling the relay. Is it OK? All those little transistors along the bottom of the page are the relay control, I see also TP17. All that has to work.Education is what you're left with after you have forgotten what you have learned.
Update
First off, I'm an idiot. I'm not sure how or why I ended up with the b2r schematic, because the schematic I needed was for the b4r (b4r and b5r share the same power amp schematic). This alleviated all of my confusion, because well, now everything is matching up from the schematic to the circuit itself. I was able to remove the cover on the relay, which enabled me to get a reading on the terminal. 15vdc like it should be. I checked all the test points in that circuit and got readings that pretty much aligned with what they're supposed to be. So does this pretty much point to the relay being bad?Attached Files
How did you measure that 15Vdc?
That circuit is a little different than the B2R.
This one employs +15Vdc on the coil at all times.
When it is engaged, Q120 will provide -15Vdc to the coil.
Thus the -11.5 Vdc of TP12.
You really should check that TP11 does NOT have gross amounts of volts dc on it.
