Hello - I have an older MP-20 mic pre that stopped working, I couldn't get any help from Presonus other than a schematic. It's pretty much a Jensen dual servo design w/Jensen input transformer The Q1/Q2 (which are actually U441 dual JFETs which I can't find anymore) appear to be bad, I did replace with two 2N4392 but did not match them and it worked for a while and then stopped. So my questions are:
1. What voltages should be set at TP1 and TP2? I'm seeing like 10VDC on TP2 which I'm pretty sure is bad. The RV2 trim pot sets some kind of bias right?
2. Do I have to have matched JFETs? What's the best replacement for dual JFET, some other dual JFET or two 2N4392 or ?
While I had one working channel, I compared a lot of voltages and couldn't find anything different except TP1 / TP2 - which were around 0V on the working channel
Thanks!
Thanks!
