1" titanium HF driver with horn for CRATE PE 15
  • 1" titanium HF driver with horn for CRATE PE 15
    Please, tell me what type of speaker 1" titanium HF driver with horn, is used in the CRATE PE 15 speakers.
    Thanks.
    Jaapi
    Look on the horn magnet, is it a Foster horn? If so the common Foster 1" diaphragm.
    Otherwise contact Loud Tech and ask.
      ^^^^ That. Or, upload pictures so we can see it. There are replacement diaphragms available for most.
ID:	847835Click image for larger version
ID:	847832Click image for larger version
ID:	847833Click image for larger version
        15" bass driver
        8 ohm
        200W avg/800W peak handling
        40Hz - 20kHz frequency response
        120dB sensitivity
          I don't recognize that driver, it certainly is not the Foster.
          That leaves contacting Loud Tech.
            Did you own the cabinet from new, or is there a chance someone replaced the horn driver?
            The diaphragm shape is like JBL 2412, but the terminals are not the same, so it's probably a knock-off.
              You can probably get a generic replacement from MCM Electronics for cheap.
                To all:
                Thank you all for your advice
                I bought the used, just Hf driver does not sounds well, so I'm looking for a replacement.
                PS:I am sorry for my English
                  Hello. Maybe I found the Hf driver. First I made a screw error for the corner - is not 1 "(I took it from the cabinet datasheet) but it is 1 3/8".
                  Then I found the PYLE PDS342 HF driver. I've bought it and I'm gonna get it this weekend.
                  We'll see :-)
                  Deneme bonusu veren siteler
                  betticket istanbulbahis
                  casinolevant levant casino
