Hello! Long time lurker who has fixed a lot of electronics with help I've found here. My ability level is decent. I can almost always solve problems when there is a smoking gun (burned parts, blown fuse, etc). I can often solve issues with no visual clues by reading a schematic. This power supply is a little beyond my grasp.
Where I'm at: all fuses check out good. None of the protect relays are closing. I've been concentrating on trying to trace out RY1 in the upper left of the schematic. Q1 has 17.5vdc on it No power on the Q2/Q3 darlington pair. I'm having trouble understanding how they are supposed to be powered. It looks like it connects to the 100V rail near Fuse F2 on the right side of the schematic. Does it get dropped down by the 100k resistor (R1)?
I'm only seeing low voltage on the C13 side of the bridge rectifier. I think that should be closer to 100V. It starts out at 15V and slowly charges the caps. That seems to make sense because RY1 is not closing to put power into that part of the circuit.
As you can see, I've worked my way into a circle unable to figure out why RY1 won't close.
Schematic for the PSU is on the lower left of the page.
