Fuse resistance
  • Fuse resistance
    I noticed that after replacing the cathode fuses in an Engl amp the power tube LED was flashing in sequence to playing. The only way is if there's either a circuit fault or the fuses have a high enough resistance for the voltage drop to trigger the LED circuit. I re-checked the amp and checked the fuses - they all read 56 Ohms, which really annoyed me as I'd just bought them and had to make up a minimum order charge as I was out of stock (T63mA).
    I did a further check and the resistance holds out even at their rated voltage and close to their capacity. Temporarily swapped them out for some T100mA and no problem.
    Really low current fuses like that do normally show resistance. My HP meter used 32ma fuses.
    So other than the LEDs blink, what problem did the smaller fuses cause?
      No other problem that I can see, though the 'scoped output increased just a little with lower resistance fuses. The originals read a little over 10 ohms so I've ordered another lot from a different supplier who lists the resistance. I would think that 56 ohms in each cathode circuit would introduce a little more NFB, as it's unbypassed. The main issue is I don't want to return the amp to the customer with a flashing LED that didn't flash before.
        I remember some of the slow blows used to have little resistors inside, maybe some still do.
        Could you just tell the guy it's the 'back-off!' light?
          I actually prefer the flashing LED. It just needs to be blue to make it a 'now' thing.
