Okay folks, fresh off the success on the Marshall - here's the next problem...
This was given to me by a neighbor who pulled it out of an abandoned house just before the roof caved in - yep
It was in pretty bad shape - PT hanging on by 1 bolt, fuseholder flopping around loose inside chassis, wrong size & wrong ohmage for speaker, missing tubes etc...
I actually got it running - all except for the tremolo. I've been staring at the schematic & the chassis for so long I've gone cross-eyed
There seem to be about 13 components clustered around the 6AU6 tube (a new one) - makes me dizzy.
I've checked all the individual components, & all cables from preamp to power amp, all seem good...
EXCEPT I think someone has been in here & flopped some components around - that just don't seem fair...
Take a look at the clusterf*%k around the 6AU6...
Transformer must have been replaced in the past, I don't think they made them with a Hammond 260... I also see 2 diodes between pin 7 to pin 3 & 5 which aren't on the schematic - but I believe this is a common mod to mitigate damage should the rectifier (6X5GT) blow...
Factory seems to have used spare (unused) pins on some tubes as convenient terminals, which just makes everything harder to follow - arrgh
I've put in a grounded plug, new JJ 6V6's, NOS GE 6X5GT & GE 6AU6, replaced all electrolytics...
Your thoughts welcome. So would a real-life visit from the nearest guru - I buy lunch
Cheers, Lorne
Cheers, Lorne
