I actually don't have much hope in this working the way a good friend of mine wants.
It's a MASCO MA 25P
He wants me to try and make it work as it used to so he can play some 78 RPM records and just have it around as a working conversation piece. Chances of the tone arm and needle working are probably slim to none.
Two questions:
1: The schematic I found shows the 2 main filter caps at 8Uf each, this one has 2 - 16Uf 600V installed. I will be replacing them but just wondering if I should stay with 16's or go for the 8's?
2: Would this be considered a hot chassis unit? If so what is the best fix? Hot chassis is new to me.
Needs every resistor and every cap replaced. It's had few things replaced a long time ago but they will also be replaced.
Only good thing is all the tube are OK.
The wires going to the turntable motor were petrified but good to go now.
Still have to cover a few spots on some of the transformer wires and then start replacing the rest of the parts.
If it doesn't work maybe it will become a harp amp.
It's a MASCO MA 25P
Two questions:
