First off... I appologize for my lack of knowledge... I've done a bit of basic repair but I am by no means a technician. I am trying to learn and don't mind putting in the time. I'm trying to repair this for our church which at this point can't afford to replace it or pay someone to repair it. I appreciate your input.
I was given the above mixer which works fine so long as the right channel is not active. If it is then the protection circuit does it's job and cuts the outputs until that channel is pulled back down. I'm not finding any articles on this happening for others to my assumption is that I have a short somewhere... Where should I start looking for the short? Could the error be in the mixing section or is it certainly in the amp portion?
The manual is here. https://www.manualslib.com/manual/89...page=29#manual
my first thought is to put on my meter and compare the output from the mixing section on each channel to see if one is sending a much stronger signal than the other... If they are the same then move on to the amp circuit looking for a short. Your thought?
