ABY Normal
  • ABY Normal
    Here are some pictures of my ABY switch in a ham can. Did you know you can get metal flake duct tape now? That's what the finish is. It works okay, but it clicks through the amp when I switch. I omitted the 100k resistors between the tip and sleeve of the A and b jacks (they are marked optional on the layout) Would adding them stop the clicking?
    http://www.generalguitargadgets.com/..._aby3lg_lo.pdf
ID:	873454Click image for larger version
ID:	873455Click image for larger version
    Vote like your future depends on it.
    Yes. But I would have used 1M resistors there. I wonder why JD used 100k.
      Dang, she IS a beauty! Fanciest dam' ABY box I've ever seen for sure.
        Thanks Bob, I'll add resistors there.
        Thanks Leo. I wasn't trying to make it fancy, though it sure turned out that way. I was really just going for easy using stuff that I already had. I did have to buy stomp switches and metal flake duct tape though.
          PURDY!
