Peavey CS800 banana binding post
  • Peavey CS800 banana binding post
    I have an email out to Peavey Parts but wanted to see if you guys have ever had to replace these and know where to find them aftermarket. They appear to be riveted to a rather long PCB mounted extension. Never seen one like this.
    Got a pic?
    nosaj
      Yes, a pic would help. There are different incarnations of the CS800.
        Not sure how you would rivet a binding pot, but they used soldered in ones for years. Yours look like this?:
        https://www.amazon.com/Binding-Post-.../dp/B00E1P3VH4
        https://www.tubesandmore.com/product...eavey-pc-mount
        That is just two sources, and I am sure Peavey has them as well. You have to CALL PV to place parts orders.
        Really old CS series amps used the posts with the brass screw down the middle, it mounted through holes in the PCB or just wires, then a nut tightened the connection.
          I'm betting by rivet, he means the connection from the post to the part that solders to the PCB board.
            That's it.Click image for larger version
              Feel like a big dummy now for not checking tubes and more. I was looking at digikey and Mouser I was having trouble finding the right search words. Thanks for the quick reply.
