Hey,
Was working on a Krank Rev Jr. recently, tubes are red plating. I would post a schematic but I can't find one anywhere. It is a cathode biased amp, seems pretty simple in terms of the OT tube stage, Cathode biased 6L6, can be subbed with 6v6 according to Krank.
Increased the Cathode resistor from 500 Ohms to 1k (quick and dirty test...) no change there. Tried with (several) known working tubes, they all red plated. (These were crummy test tubes FYI).
The Plate / Grid voltages are:
WITH TUBES
Pin 5 Control - 30mv
Pin 4 - Screen - 267VDC
Pin 3 Plate -243VDC
WITHOUT TUBES:
Pin 5 Control 0mv
pin 4 Screen 411 VDC
pin 3 Plate 411
From my limited knowledge, I am under the impression that Screen voltage is kept slightly below plate voltage to help control the current in the output tubes. if this is true, could that be the source of redplating for the tubes?
And further, can someone help explain the relationship between the screen and it's control circuit? Without a schematic (and with an untraceable, unremovable PCB) I'm at a bit of a loss.
Thanks in advance,
Mr. B
WITH TUBES
Pin 3 Plate -243VDC
WITHOUT TUBES:
Pin 5 Control 0mv
pin 3 Plate 411
Thanks in advance,
Mr. B
