I assume you mean an input signal shows up on the VU meters but nothing comes from the speaker output connections? Then first thing I look for is blown fuses in the power amp circuits. And unfortunately, fuses usually blow for a reason, most common reason would be a failure of the power amp.
thank you for the response
yes it is an EMX..........How can I check the fuses ?????.........
I don't hear the fan running either ......and I understand that could lead to overheat .....
so where do I start ?
thanks for the response ..........how do I check the fuses?????..........
would the fuses blow if the fan stopped running ???
does the fan have a fuse ???
