Hello at all, sorry for my bad English, i'm French
We have a Peavey Musician Bass MK III with stange problem.
Amp Working, but after several minutes headsink become very hot and amp stop to work in thermal shuntdown.
After check we have found 2 transistors with realy bad values on right bank. we have remplaced the 4 transistors in bank.
Before turn on amp, have check mesure between E,C,B's transistors and ground, check in not shorted connexions
But have arround 1 ohm between Q8,9,10,11's Collector and ground , strange ... !
Plug amp with a light bulb limiter wired in series, but ligthing immediately ... I suspected this ...![Sad](https://music-electronics-forum.com/core/images/smilies/icon_sad.gif)
This amp have output transfomer, I disconnect this, annnnnnnnnd ... amp working ...
I measure the windings, have 0.44 & 0.88 ohms between ground plug on schematic and 2 other wirrings, I find it very weak !!!?
OT seems shorted![Sad](https://music-electronics-forum.com/core/images/smilies/icon_sad.gif)
how did the amp work before ?!?![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
Does amp can working without this OT ?
Or maybe other problems ?
Thanks in advance for your help.
Regards.
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
OT seems shorted
Regards.
