P channel JFET as audio switch
Hi.
I recently built a 4 channel audio switch for a client. I was in a rush.
I decided to use a circuit described on the net “Audio switch notes”. It uses a P ch JFET. See the first of the two attached circuits.
It works great except that the signal gets clipped at louder transients.
Im wondering if this is caused by the absence of a gate diode in the first attached circuit. The second attached circuit has the diode along with an N ch JFET.
Could this be the cause of premature clipping of the signal?
Hi.
