Originally posted by Reader
View Post
Speaker coil winding
Originally posted by eschertonSame current but fewer Ohms. Power = I^2 * R so fewer Ohms for the same current means lower power rating.
There´s more parameters involved:
* coil diameter
* winding length
* actual wire diameter (which may or may not match what raw Gauge # indicates)
* number of turns
* insulation thickness
* copper or aluminum
* number of layers.Last edited by nosaj; 12-02-2018, 11:12 PM.
Originally posted by anchor View PostThe power dissipated also has a voltage perspective where it does not change. If the amp used with the original voice coil is 100W rated at 4R, reducing the voice coil resistance does not change its power rating. Note p=v2/r, when you halve the resistance, more power is dissipated. The post by nosaj seems only half true and does not tell the whole story.
Of all those listed above, the "winding length" appears to be the only factor relevant to the case above. The number of turns only changes the impedance, not the resistance.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by anchor View PostThe number of turns only changes the impedance, not the resistance."Take two placebos, works twice as well." Enzo
My layman's approach would be like this:
Speaker power rating is determined by its max. voice coil temperature. The voice coil gets heated by the power dissipated in its DCR and is cooled via heat radiation to the surrounding structure and by convection.
An example: An 8 Ohm/50W speaker can take 20Vrms. This means a current of 2.5Arms. It DCR is typically 6.4 Ohm (80% of 8 Ohm), so the max. dissipated thermal power is 40W.
Everything else being equal, the 4 Ohm version of the speaker needs to have a DCR of 3.2 Ohm for a thermal power of 40W and a rated apparent power of 50W.
Everything else being equal means that both voice coils should have the same surface area and (thermal) mass. Realization (including achieving the necessary inductance to get a Z of 4 Ohm) will require a heavier wire as well as less turns for the 4 Ohm version. The optimization process probably requires some iteration.
I am aware that I ignored radiated acoustical power, but this is assumed to be the same for both versions.
Surely JMF knows better.- Own Opinions Only -
Originally posted by Helmholtz View Post- - -. The voice coil gets heated by the power dissipated in its DCR and is cooled via heat radiation to the surrounding structure and by convection- - -Keep learning. Never give up.
Originally posted by nosaj View PostSo in simplest terms what I said is correct "Same gauge fewer turns means less power handling." Which anchor took offense to.
nosaj
Max. speaker RMS current at middle frequencies (ca. 300..500Hz) is determined by its power and impedance ratings. The thermal power is given by I² times DCR. So in principle less DCR means less voice coil heating. Same gauge half turns number would meet the 3.2 Ohm DCR requirement for equal thermal power. But this would decrease voice coil volume and surface causing excessive VC temperature, in other words: less power handling.
Also to meet the 50% inductance requirement, turns number must be decreased by only 30%.
This means that wire gauge must be increased to get a DCR of 3.2 Ohm with 70% turns and to get enough voice coil volume and surface.
Most surprisingly my measurement on 16 Ohm and 8 Ohm Celestions confirmed the 2:1 ratio of DCRs but the inductance ratio was only 1.6:1 (@1kHz). This shows that there is some leeway regarding actual number of turns.Last edited by Helmholtz; 12-03-2018, 10:07 PM.- Own Opinions Only -
