The right speaker on my 33 year old Sony MDR-V6 headphones does not work. Up until recently I could get the right speaker to work by pulling or pushing on the left speaker wire, but the right speaker will not work at all anymore. In the past I could get the right speaker to work by pulling on the right speaker wire. I took the speaker covers off and looked at the wiring on both speakers. All the soldering on the left speaker wires appear fine. One of the wires for the left speaker is frayed a little. The single wire for the right speaker is frayed a lot. I moved all the wires around on both speakers but could not get the right speaker to work. Thanks for any replies.
Sony MDR-V6 speaker does not work
Use a meter to check the wires from the plug to the speakers. See if one has no continuity (probably the right pos wire). Most likely there's a break where the wire enters the headphones or crosses sides- where the wire is flexed most often. You won't probably see it. You'll just have to replace it or cut the existing wire shorter and rewire them. If you don't have continuity issues, you could have a bad earpiece, but I doubt it.Last edited by The Dude; 12-19-2018, 12:27 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
All the wires from the plug to the left speaker look fine. The wires from the plug to the right speaker are extremely frayed. The tan part of the wire was still connected to the solder glob on the speaker, but the red part of the wire was totally disconnected. I cut the wire off and removed a half inch of insulation. Some of the tan fibers of the wire are mixed with the red fibers. Is it necessary to completely separate each fiber by color, or can some tan fibers be mixed with the red fibers and vice versa? Do I now just solder the plug wires back onto the speaker? Thanks.
Hard to say for sure what you have. Maybe a picture would help. I'm guessing ,without actually seeing anything, that the red coated wires are the positive connection and the tan are the ground/negative connection. If that's the case, yes you'd have to separate them first. It's all easy enough to check with a meter."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The tan and copper strands are mixed:
Separating each strand may not be possible even with a magnifying glass. What if I cannot separate all strands?
After separating the strands do I just solder the separated strands anywhere onto their corresponding glob of old solder on the speaker?
I have a multi-meter. To check for continuity I place one probe at the end of one separated group of wire strands and the other probe further up the same group of wire strands? Both group of wire strands should have continuity if I separated the strands sufficiently, correct? Thanks.
Sorry, I can't tell enough from the 1st picture to see what's going on, so I'll just say this. There will be 2 connections in that wire. It could be the different color strands, or a shield that got cut and is still in the wire jacket. One connection will go to the sleeve of the plug. The other will go either to the tip or ring (one is left and one is right). Like this:
Your job is to use a meter and find which wires go to which parts of the plug. Then solder the "sleeve wire" to the negative speaker terminal and the other to the positive speaker terminal. If you are unsure of how the conductors are arranged in the cable, you could carefully remove the other earpiece and see how it is wired. Again, the picture is blurry enough that I can't tell for sure, but it kind of looks like the brown "wires" might just be some sort of string there to add durability."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Also, stripping back some more of that insulation might show the 'grouping' of the strands a little better.
But agree with The Dude, looking at the other side speaker should show how it is.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Fuzzy picture but I think I see bright shiny copper wire and tan "textile fiber" which is just cushioning.
Forget textiles, concentrate only on copper.
It is color coded, but sometimes it´s green or red (easy peasy) others "natural" copper (with crystal transparent enamel) and light brownish/reddish enamel, harder to distinguish one from the other, specially for tired old eyes (anything above 40 y.o.)
Agree with looking atb the other earbud and its soldering.
IF possible, replace wiring.
Oh: and measure DC resistance across each earbud speaker, you should measure about 30 ohms DCR at each.
If open, junk it and buy a whole new one.
EDIT: I strongly suggest buying a cheap jeweller´s loupe, not only for this particular job but everywhere:
The speaker wire does consist of two different colored wires and the textile fiber. One wire is bright red and the other is tan. I was able to separate all of the strands of each color with the aid of my 16x magnifying glass.
There are leftover red wire strands on one solder glob and leftover tan wire strands on the other solder glob on the speaker. I placed the red strands from the speaker wire onto its corresponding solder glob on the speaker and placed the tan strands onto its corresponding solder glob, but the speaker did not work.
I placed one of my multi-meter leads at the wire plug in various positions and the other lead onto each exposed wire in various positions, but my meter did not beep detecting continuity. I also placed one meter lead at the base of the wire insulation and the other lead at each wire end, but the meter still did not detect continuity.
I placed one lead on one solder glob on the speaker and the other lead on the other glob and got a reading of 68 Ohms.
Originally posted by The Dude View PostOne possible problem is that the wire is coated and not actually soldered, yet. You may have to scrape/burn off the coating before you solder it.
All you need is a normal/hot soldering iron.Juan Manuel Fahey
