This is a 5150 III. I found several threads with a similar symptom but a different problem. I did find good schematics and will forward if somebody is interested.
Channel 1 and Channel 2 are very faint. Channel 3 appears to be normal. The original problem was "no heater voltage" which I verified. I temporarily fixed the heater problem by changing fuses, heating the holder and also soldering the spade connectors that attach to the pre-amp circuit board. I realize from another thread that I'll need to change the heater fuse holder.
But the problem now appears to be in V1. Only 1/2 is working.
