View Post
OK Then
Originally posted by Tone Meister View PostAnd I am all about gutting it and rebuilding it right on an eyelet board. As soon as we figure this out, that is exactly what I'll do. The soldering is amateur and as pointed out above, some of the wiring and component placement are poorly implemented.
nosaj
Just thinking out loud...using a scope at the input then input of 12ax7 and so on. You could see the signal size increase and at some point see it choke out.soldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by nosaj View PostDon't underestimate the resistance of a bad solder joint.
nosaj
Originally posted by Tone Meister View PostThe amp works fine and sounds fine. It was purposely built for 1 watt output but the new owner (my buddy) now wants full output.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by nosaj View PostScope might make it faster and easier to see the signal changes throughout the amp. IT's being choked or throttled at 1 watt output somewhere
nosaj
I don't have a scope at present. Mine was killed over the summer. Got one incoming, but not today.
Originally posted by Tone Meister View Posthttps://music-electronics-forum.com/...ad.php?t=48333
In the first picture in post #20, there looks to be a 100 ohm resistor (about middle of pic) going to a pin of the 5Y3. Can you tell us if it is indeed 100 ohm and where it actually goes.
Edit: Or maybe it just looks like 100 ohm in the pic and it's actually a 10K?Last edited by The Dude; 01-30-2019, 02:05 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostIn the first picture in post #20, there looks to be a 100 ohm resistor (about middle of pic) going to a pin of the 5Y3. Can you tell us if it is indeed 100 ohm and where it actually goes.
Edit: Or maybe it just looks like 100 ohm in the pic and it's actually the 10K?
Originally posted by Tone Meister View PostBoth are 68K. Blue, Gray, Orange
[ATTACH=CONFIG]52281[/ATTACH]
