I recently purchased a used and sightly abused Fender Princeton 112 Plus that had a few issues such as a reverb control with a loose shaft and missing knobs. I have it functional but when the power switch is turned there is a loud pop from the speaker. I am worried about damaging the speaker if this is not repaired. Any suggestions? Thanks in advance.
Fender Princeton 112 Plus power switch pop
The pop won't damage the speaker. Try the test of plugging the power cord in while the power switch is on and reverse that by turning it off by unplugging the power cord. This will tell us if the power switch is arcing which could make a popping noise at turn on/off. Then again many amps pop when turned on/off. Start with that test and report back to let us know the results.When the going gets weird... The weird turn pro!
Originally posted by Kirby02 View PostI recently purchased a used and sightly abused Fender Princeton 112 Plus that had a few issues such as a reverb control with a loose shaft and missing knobs. I have it functional but when the power switch is turned there is a loud pop from the speaker. I am worried about damaging the speaker if this is not repaired. Any suggestions? Thanks in advance.
Originally posted by Jazz P Bass View PostTo see if it is a preamp or a power amp issue, insert a plug into the Return jack.
That plug will isolate the preamp from the power amp.
Princeton 112 Plus Service Manual attached
Originally posted by 52 Bill View PostSchematic?
Does that amp pop when there is no guitar cord plugged into the regular input?
Princeton_112_Plus_Service_Manual.pdf
So, breaking the signal between the Preamp Out (at the Send) by inserting plug (or guitar) into the Return jack eliminates the Turn-Off pop. Does it do the same at turn-on?
A brief look at the schematic shows a 22uF coupling cap at the preamp output (C32) ahead of the Send Jack, while following the Return jack there's just a 470nF cap (C34). Nothing large in stage-to-stage coupling upstream in the preamp circuits. And, in the power amp, there's the bootstrap cap C40 that can also produce a pop at turn-on, while everything is charging up all at the same time.Logic is an organized way of going wrong with confidence
Originally posted by nevetslab View PostAh....solid state amp. That begins to suggest things.
[ATTACH]52382[/ATTACH]
Originally posted by Kirby02 View PostYes it does but not as loud as when the guitar is plugged in. If I can't find a fix this will be the shut off procedure I will be using.
SO the preamp is picking up the pop. Probably a spark in the power switch.
Try this, leave the power switch on, and just pull the power plug from the wall outlet. Does it still pop? You might need nothing more than a cap across the power switch.
In my shop we do not consider pops a problem, it will not hurt your speaker.Education is what you're left with after you have forgotten what you have learned.
