I have a customer that wants to run his MC 250 in mono mode with a 4 ohm cabinet. The online owner's manual (for a later version) sez set the mode switch to mono, jumper the two 8 ohm output taps and use the common and the 8 ohm tap as the output to the 4 ohm load.
The problem comes in that his amp is one of a series that has a circuit where the mode switch internally connects the two 4 ohm autotransformer taps when in mono mode. Does anybody have the correct mono mode speaker load connection for this version of the amp?
The owner tried using the jumper from 8 ohm to 8 ohm taps, but the amp starts to overheat and has reduced power output.
