Peavey XR8600D powered mixer no output
  • Peavey XR8600D powered mixer no output
    No output signal and no DC on the outputs.
    Power supply voltages check good.
    I get signal through the aux input from the mixer to the power amp board on J11 as seen from my scope. I have signal up to around IC102 and then lose it.
    Looking at this and I am thinking I may be in over my head with this one. SMD, 300V superfets, no fuses, driver shutdown circuitry...
    I see test points but I don't have any documentation as to what they should be.
    Any of you Peavey guys/gals have any experience with these and can impart some wisdom?
    XR pwr supply D.pdf
