I'm so so sick of dealing with internal multi pin connectors that tend to make intermittently lousy contact with one of more pins. Seems like with some of them it;s not a matter or whether that will happen, but when. My latest PITA is with an amp i really love when it sounds right, a fender GT100 mustang. This think has had several volume and tone issues that seem to have gone away once i dealt with one particular connector. It's not a ribbon or wire type, but a multi pin connection between 2 boards. They type where on board has pins soldered to the board and the other board has a female connector soldered directly to it and the smaller board presses into it when positioned into place. The thing is so flimsy, and the fact it is the send/return board tells me we're dealing with a analog signal path which is likely where these intermittent tonal and volume fluctuation are happening, and seems to be proven by the fact it stopped after i modded it. It's all common stuff with many owners, not just myself. But the mod was a crude one and a PITA.....18 (at least i think theres 18 pins) 3-4" pieces of wire soldered to the connector pads on each board to keep all connections solidly intact even when the pin connections fail. A real PITA and tedious/long mod. I tried deoxit initially and that worked for a time then started again. I did the same mod to the other such connector in it thats on the footswitch board. The FS issues topped after that so these connector types are truly crap.
Question is, i intend to buy a second one as a backup and to keep at a friends rehearsal space. I also have a friend who likes the amp and wants to buy one but i advised him of this issue. So my question is, does anyone know of any tricks to make connectors like this reliable? I thought long and had but all i could come up with is the mod i did which i really do not want to go thru again if i buy another and then again if my buddy buys one. What a garbage design ! Gotta be a easier way to deal with it and there are a lot of electronic wizards here so i gotta think someone has come up with a way around this.
