high technology. keep yourself up to date or die.
  • high technology. keep yourself up to date or die.
    I purchased a soldering / desoldering station.
    A clone one, cheap but good. Not a hot air one, the more "traditional" through hole model.
    Though my soldering iron has been serving me for years and years just having to replace periodically the tip, I have to admit that the upgrade is nice.
    Well while I was at it, I purchased a few spare tips and such, typical, and a tip temperature thermometer because the deal was good compared to other sellers.
    Well, I haven't received the thermometer yet and I have been soldering a lot since I bought the station, quite worried and feeling impatient for the arrive of the indispensable thermometer because I like to have it all, and all, right.
    Well, then I took a break to think about it. How could I have survived for so long with my trusty iron without frying opamps, germanium transistor and the like?
    Yeah they seem to sell those hot air ones for SMD mainly, mobile phones etc. They're getting quite cheap. Are they any good for speedy clean-up of 'traditional' boards?
    I have a hakko temp controlled iron. It is excellent and apparently the tip is everlasting. Wouldn't mind a desoldering unit as good.
      Well at least mine is. I wouldn't mind if the pump had a little more suction power but that's because point to point circuits usually have bigger solder points.
      On normal 'traditional' boards you desolder one leg of a resistor and when you do the other leg the component usually drops down free and clean.
        Oh man. What is it I want one.
          A desoldering gun. Mine is part of the station, but there are stand alone units just for desoldering.
          The trick as I have learned is to keep the inside of the gun completely clean and not to wait for too long because it looses suction power quite easily.
            And keep the filters clean.
            holiganbet betturkey
