Hello folks,
I know keyboards are not the forte' of this forum, however I have to think some of the techs here work on them. I have 2 Korg keyboards with the RH3 or 4 keybed (one us 77key & the other is 88).
The felt that dampens the key weight on the downward keystroke (the weight moves upward on the downward keystroke) has become NLA and I'm looking for a source or someone who has found a solution perhaps using a felt from something else.
I found on PartsIsParts.com the Yamaha felt but it is too tall (15mm). the original is 10mm x 7mm. The 7mm dimension could also be 10mm but the 10mm height is crucial for interaction with the aftertouch pad under the front of the key. 5mm difference would upset the key travel and make the playability too drastic a change to be of any use.
The part number in question is in the PartIsParts.com site as 510500506601. According to the dude there, there is no ETA. I have an sample felt coming from a felt mfg, but won't know if the weight of the felt will be compatible until I receive it. I'm skeptical as the density of the felt has to be just right to dampen the weight while at the same time not being too hard or too soft. The original is actually about 3 layers of differing felt densities.
So, if anyone has any ideas, it would be greatly appreciated.
Thanx, Glen Whatley - Mars Amp Repair - Nampa, ID.
