GSSL Clone
  • GSSL Clone
    I've found some PCB's for build an SSL compressor. But, checking the BOM list, schematic and board, I found some differences. I've solved all of this, only for two resistors.
    The schematic on gyraf site, says MANGLER 22R - > LUS V. -15V
    http://www.gyraf.dk/gy_pd/ssl/ssl.pdf
    Tells that they have two 22r resistors on the 7815 and 7915, but my board haven't this two resistors. What happens if I omit this two resistors?
    Schematic:
    https://ibb.co/HD9z398
    My board:
    I remove resistors in green, because I have a THAT 2180BL08-U.
    Resistors in red, are missing resistors or different values.
    https://ibb.co/nwtfsBD
    Thanks.
    Looking at your pcb : the second pair of 1000uF/35V is omitted too.
    The 22R resistors you're lookinf for are the 10R resistors on your PCB.(Between bridge and 78L15, 79L15 )
    Then again, tracing the circuit is not easy just by looking at that picture.
